rocksteady_racer »
https://forums.nicoclub.com/rocksteady-racer-u29694.html
Sat Jul 23, 2011 1:54 pm
I'm reclocking the oil pump, so that's what I was talking about, I guess I'll just flip it around. As in the sprocket for the oil pump had to fall out for me to pull the cover so that's where I am. But all the msg board posts say put it in so it's a straight up and down D, which I did but then the dizzy was on the 3rd cylinder as I said. The engine is set to tdc, positive about that. So I figure they all really meant a backwards D, or my distributor is confused, but either way I'll just flip it around, timing should be perfect then.
