TheOne »
https://forums.nicoclub.com/theone-u18820.html
Fri Nov 17, 2006 6:14 am
smoke comin from the manifold is ok, its the gasket seating in, but yes you do have to fix the timing, another way to check if it moved and to compensate is to take off the dist cap, then you can check and align so that the rotor is pointing @ the #1 spark plug wire.
bad noise is probably cause you forgot to prime the motor before turning it on(prime, as in make the oil flow without lettin the engine run), and you prolly need another half quart of oil(do check the dipstick first)
i just finshed helping my friend install his rebuilt engine yesterday, thats why i remember most of it.
