So today the weather was a bit nice so I decided to take the upper timing chain guides off. So, I removed the distributor and the camshaft sprocket cover then removed the guides and installed everything back in. I thought I installed the distributor correctly but when I tried to start the car this is what happens...
http://www-personal.umich.edu/~taesoo/MVI_2314.AVI
Sometime it would crank for a sec then boom that happens...
Am I off by a tooth or something? I thought the car would atleast start if Im just a little bit off... Did I miss something else? Please help.
This is what it looked like BEFORE I started taking everything off. This was at TDC @ #1 cylinder. I positioned the distributor just like the picture but... arg
Modified by ILikeMy240sx at 7:12 PM 3/4/2005
