Distributor Cap/Rotor
wangless
Car: '02 MBP WRX
hi,
ive tried looking, but i didnt find what i was looking for... from courtesy nissan there are hitachi/mitsubishi caps/rotors... and they say to check the old one before buying... curious just because i dont know anything about the caps/rotors...
where would i find them, how would i install them, which one do i get ? thanks sorry if this is a repeated thread, but i couldnt find anything
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
By-- rps13-- do you mean you have an SR. Must specify.
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
D-UNIT wrote:By-- rps13-- do you mean you have an SR. Must specify.
Not really needed as the SR doesnt use a distro.... So hat would rule the question our if he did.
The cap and rotor are on the distributor, the thing all the plug wires go into :)
To take the cap off just unplug all 4 wires and the coil wire (s13 only) then remove the 2 8mm / phillips screws... Thats it.
For the rotor youll pull that straight off when the cap comes off.
wangless
Car: '02 MBP WRX
thanks !
wangless
Car: '02 MBP WRX
umm... courtesy nissan said to check before... i think they mean that i should check for either the hitachi or the mitsubishi type... but i dont see any... does it matter which one i use though ? or it doesnt matter... or it actually does ?
96_S14_SE
I really dont think it matters but there may be a design difference in those years I dont know of...
FWIW I have a mitsu distro cap on my 96 dohc.. Not the word but just the tri star emblem on it.
Touchdown038
Car: Computers, cars, sports
96_S14_SE wrote:For the rotor youll pull that straight off when the cap comes off.
You sure you just pull it straight off? In my Mitsubishi system on my 89, the rotor had a screw on the backside that I had to take out first.
D-UNIT
DOH!!!!! someone doesn't have an sr do they!! Just changed mine. Made the mistake of buying aftermarket (bad move). Bought nissan 3 months later. It had a mitsu emblem on it too. The rotor pulls right off. 91' DE
wangless
Car: '02 MBP WRX
anyone have a hatachi one ?
moondog52
Ditto here ... I have an '89 with Mitsubishi ... the rotor has the screw on the side. Just got done replacing cap, and rotor ... amongst $800 worth of other stuff.
Well, $350 was for the tires ;)
96_S14_SE
Sorry about that pull off deal... 99% of my experience comes from the various s13 / s14 Ive owned / repaired with DOHC ka's..
Ill keep note of that though :)
BSTN240
Car: pool, paintball, working on cars
does anyone know how to tell the difference between the mitsu cap and rotor and the hitachi? do all mitsu's have the tri-diamond emblem? i need to change my cap and rotor and have no idea which one i have. thanks.
Chris28
Car: 92 s13 KA-T
Bumping this mega old thread because I just ran into this issue. The Mitsu cap is indeed different from the Hitachi cap and they are not interchangeable. When looking into the cap, the pickup points on the Mitsubishi cap are .65mm deeper than they are on the Hitachi cap. It bolts on fine and idles fine, but since the rotor doesn't touch the pickups it feels just like spark blowout at anything more than 25% throttle.
You might be able to put the Hitachi cap on the Mitsubishi dizzy, but I'd keep them together.
