The fact there is absolutely no spark from cap to plug wire, but spark from spark plug to end of wire. Battery is brand new and tested good and starter is good. There is no codes being thrown or soft codes stored and the truck wont start.Chuck Tribolet wrote:What makes you think you need a new distributor? That doesn't seem to be a normal point of failure in 3.0/3.0 litre
Pathfinders.
Chuck
Have not ever pulled the distributor out and no work was done when it wouldnt start.Chuck Tribolet wrote:Distributors are dirt simple.
Was any work done on it when it quit? Could the distributor be installed 180 a tooth off?
Have you replaced cap and rotor?
Chuck
They sure are. If its not those 2 pieces then I have a cap and rotor laying around that I cant do anything with and I wasted $50.00pathyse wrote:Cap and rotor are CHEAP, start there first. Unlikely it's your whole distributor.
Not a clue. Ive only owned it for a few months. Ive got about 1-3 years worth of maintenance records and it has never been done.00pathyse wrote:Unless you've messed around with yours in some way you should not need to replace a distributor. Cap and rotor are maintenance items and need to be replaced periodically. When was yours last replaced?
Unplug the coil wire from the distributor. Hold it close (1/8' or less) to a good ground while a buddy tries to start the truck. If it's sparking,whitedragon551 wrote:How do I test for spark from the coil?
I will be checking that today. Wouldnt I get spark from the plug wires off the distributor if the coil was getting spark? Seems like its an obvious chain of events.Chuck Tribolet wrote:Are you getting spark from the coil to the distributor?
Chuck
Either way its a distributor issue right?Chuck Tribolet wrote:It's possible that the coil is supplying spark, but the distributor isn't distributing the spark.
But the coil isn't supplying spark, your have to look at the coil and the low voltage side of the distributor.
It's about tracing the bug back to it's source.
The FSM should have a debug procedure.
Chuck
Pathfinders.
Chuck
It ran fine one minute. I shut it off went inside and came back out to start it and it just wouldnt start.fueler wrote:Chuck Tribolet wrote:What makes you think you need a new distributor? That doesn't seem to be a normal point of failure in 3.0/3.0 litre
Pathfinders.
Chuck
His 1998 QX4 (same as Pathfinder) is a 3.3 liter. I actually had a distributor go bad on my 3.3L (well, technically it wasn't the distributor itself, but rather the camshaft position sensor which is a part of the distributor and cannot be replaced separately). This happened at around 175k miles.
When it failed, the QX4 quit running but it also threw the code for it immediately, which made diagnosis a breeze.
No, it could be a bad coil.whitedragon551 wrote:Either way its a distributor issue right?Chuck Tribolet wrote:It's possible that the coil is supplying spark, but the distributor isn't distributing the spark.
Chuck
