Distributer
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
jetjocks2003
Does anyone reconize this distributer? was in a 72 521, is it worth replacing mine, that has the pertonix kit
jetjocks2003
THe numbers on it are: D4R82-13 2904
                                   22100 34M00
71-521
from the numbers you posted it is a 83 model year with 13 degrees total advance at 2600rpm...did you grab the matchbox with it and the pedestal? could be a pain mounting it without...
jetjocks2003
Where does the "matchbox" mount?  It seems that the wires were just attached to the coil, there is what appears to be an ignition modual in the dist.  Unless it mounts next to the coil, but I was under the impression that it mounted externally to the dist. housing.
IMH
Wouldn't an 83 be a 720 with a NAPS Z engine?  A Z22 with two spark plugs per cylinder?  Maybe check those numbers again against what ever gave you that year.
jetjocks2003
The way its set up it looks like it will cross two feilds at once? To me it could be a naps.
jetjocks2003
The engine in the junk yard truck was not a naps Z, it was on older (then mine) 1600, with the timing pointer on the lew rt, and the graduations on the fly wheel.
jetjocks2003
This site has gotten kind of quiet, alot of poeple are in Oregon somtimes working the weekends gets old.:X  Have Fun!
Matt
71-521
The numbers you posted are listed on a chart I found somewhere...can't remember where it was but I have it backed up here:
http://521.no-ip.info/521/index.php?showtopic=36
79 was the begining of the "matchbox" dizzy...I just figured if it was a 83 then it should have it but remembered afterwards that not all dizzy's came with the electronic modules...:shock:
sorry it took so long to reply....I was in Vegas for a son's graduation!
jetjocks2003
do you have a part number for the cap that belongs to this distibuter
Return to “Datsun Chat”
