Distributer.
d1_king
Car: 240sx
on a 95 and up engine do you have to use the s14 distributer or can you use a s13 one on a s13 or do you have to change the main center gear to a s13 one where the distributer goes in?
driftsiidwayz
Car: 1995 nissan 240sx SE
s14 dis.
d1_king
Car: 240sx
oh word so you basically can use the s13 one at all?
kpc_0721
Car: 1991 240sx hatchback
So does that mean you can use a s13 distributor without changing anything or you cant?
TheOne
Car: 93 240sx FB
if the ecu/wiring harness is from an S14(95+) going into an S13 engine, you have to use the S14 distributor, you can however, wire up an S13 distributor to work with S14 wiring/ecu.
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
both have the same trigger disc and optical sensor. s14 has an internal coil and power transistor, while the s13 is external. if you can figure out the changes needed for this, you can do it and then have the upgraded coil options, if not, you're SOL, pay me to do it
