Distributer compatability question
pella
Car: 1995 240sx S14
The cam angle sensor in my 95 KA went out. I have borrowed a friends distributer but need to give it back. The question I have is will a distributer/ cam angle sensor from a 92 DOHC work on my 95? Im not sure if there would be problems with OBD1 to OBD2. I found 1 for $30, its alot less than $300. Just wanna make sure it will work.
jazz4890
Car: 1991 Nissan 240sx
Yes the distributor can work with your 95 motor but the distributor on the 91 motor and your 95 motor must be on the outside of the head for it to work. Meaning the dustributor is not inside of the head like most of the newer obd2 ka motors. Hope that helps
pella
Car: 1995 240sx S14
Can work? LOL Spoken like a 240 owner. So a 92 is the same as 95 then? thanks
The_caveman
Car: 93 nissan 240sx hatch(daily build)
1992 Coupe (drift build)
1990 240sx hatch(wrecked slut)
2008 hyundai sonota - girls car/reliable! i drive it better tho ;)
So uhhh i have no clue what the guy that who was telling you it will work is talking about.....
On the off note they will not work, the dizz on a 92 ka requires a 5th sparkplug for an ignitor...s14 distributers have one internally eliminating the need for the 5th plug... Put simply it's a no go, there are quite a few parts on s14s that aren't swappable with an s13... That's one of them
pella
Car: 1995 240sx S14
I knew the SOHC had the fifth wire, but was hoping that it would work on all DOHC KA's. I talked to the guy who has it, he said there is 4 wires..... I dunno . Will have to check it out tomorrow.
mixeds14
Car: 240
first, your car being a 95, it is a obd1, 96 and up are obd2. and the dizzy for 95 and up are the same... that being said i have one of a 95 that i parted the motor n i have a 96 but its on a complete motor that i have incase i come across a good deal on a shell....i dont know if 92 would be the same but i sell u the one out of the 95 i u liked
pella
Car: 1995 240sx S14
Thanks caveman. You were absolutly right. Theres a fifth wire for the coil.
Mixeds14- how much?
mixeds14
Car: 240
pm'd
