Distance to empty won't reset on refill
wdebow
Car: 2012 Infiniti M37 Base
Anybody know how to fix?
Ilya
Try clearing the fuel counter completely by holding the circle button on the right side of the speedometer to clear the speedometer unit or clear the one on the big screen via the fuel menu.
JCesar
Maybe also unplug the battery for 10 mins to reset everything?
cliffyk
Car: 2012 Infiniti M37 Premium Pkg
JCesar wrote:
Sat Nov 24, 2018 12:18 pm
Good suggestion, however as a "addon"; often with modern vehicles depressing the brake pedal while the battery in dis connected will cause any power backup capacitors in the various microcontrollers to drain as well. Many of these systems use so little power that capacitors are used as backup "batteries", forcing the brake lights drains them dry...
