+11111 The VDC cuts out all of the fun stuff..G_whizz wrote:Did you drive it with the VDC off?
Not even in the 5 seconds range with a 04 with a AT to add, considering the 07 g35S with the 306 HP engine does it a little under 6 seconds. True figures of a 04 AT 0-60 are more in the ranges of 6.5-7.0szozoka1212 wrote:Yeah, I am not sure about the 04 coupe(it supposely 5.6-5.8) but the Celica is well over 6 seconds 0-60. I think it is just your mind playing. Sometimes the car feels faster than what it is. Some others feels slower but they are not.
zozo
I think its a little more the just traction control. Below is a VDC on run vs a VDC off run!audtatious wrote:VDC is pretty much TCS...Traction control. In the G, if you have VDC on and punch it, it will engage if it feels the wheels may start slipping. At that point, it applies the brakes to the rear wheels.
Exactly... nothing left on the table. did you see my post above your probably looking at low $20's for an 04 coupe why not buy a faster 07 sedan for $26?Sentientbydesign wrote:It's interesting that on the I30/Maxs we can pull 30whp out of our butts by swapping a y-pipe and doing CAI and catts.
I guess Infiniti did a good job of designing for peak performance.
It is very possible for you to have lost some low end power and gain some top end. This happens alot when you go to a more free flow system. I bet you are a tad slower from 0-60, but a bit faster from 60-120.zippyslug31 wrote:Had mine only a short time before I threw on my intake (non- Ztube... just a cheapie). Have also since replaced with a CX Racing cat-back.
Got to be honest though that I don't feel it is any quicker and, dare I think it, possibly slower??? I definitely think it likely has a little more top end but just off the line it seems to ever-so-slightly have more lag.
Could be simply a matter of me being used to the power now? Maybe a lack of back pressure is messing with the speed off the line?Would be a really fun experiement pulling out the stock intake and exhaust and reinstalling them just for comparrisons sake.
One thing that I think was an evident result though: according the the MPG/nav reading, the intake bumped this up by 1 mpg. That was a nice surprise though I don't know if this is "accruate and true" data.
I don't see what you're trying to get at? i stated that the times were a little under 6 seconds 07G35 which is exactly what you posted? did you read my post? And you stopped watched yourself for a 0-60? what kind of joke is that with obvious human error .You also fail to consider high elevation locations such as where i live in calagary, which also mean loss in power due to lower oxygen.""I've stop watched my 07 Journey sedan in 5.0 flat with a passenger"" Wow you should be able to destory a G37S easy with your "stopped watched 5.0", considering the g37 is sub 5 second range, and you with a passenger!.gwoods wrote:
0-60 in 5.3http://www.motortrend.com/road...sport/
0-60 in 5.2http://www.caranddriver.com/ro....html
I've stop watched my 07 Journey sedan in 5.0 flat with a passenger.
In the slip I posted about my 1/8th mile with traction issue in hot weather was a 9.125 at 78.801 find a racing calculator and plug that in and you'll get a 5.2 seconds to 60 estimate. Apply a SAE correction for weather its a 4.82 seconds to 60 mph.
I'll post a 13.7 second 1/4 mile slip in January. Even with the huge power loss from my only mod the fujita intake.
Jeff
I don't know if your being sarcastic or not but yeah I think I can beat a G37 with my G35 sedan.MagicM wrote:
Modified by MagicM at 4:23 PM 11/15/2007
WHOA WHOA WHOA!gwoods wrote:My advise is to search the infiniti dealers in your area a find a used 07 sedan?
07 sedan with 18k miles for $26k
http://www.autotrader.com/fyc/...light=
