dissable speed limiter??
hek1620
Car: '89 240sx
she feels like she can do a lot more. so i was wondering if theres an easier way to cut the limiter than to unplug the gear sensors on the transmission. also to keep the speedo working.
halfassracing
Car: 1993 nissan 240sx
not with out up grading your ecu. or putting in a chip, you could just put it on a switch and right before you hit fuel cut flip the switch. your running a sohc right. not much need to bypass fuel cut but its your car. i had a buddy with a 89 240 in the quarter he would spank alot of cars, and his was almost stock. i guess it all depends on the driver. if you run for a short ways then realy no need to bypass.
DirtySouth
Car: 91 240sx coupe
change to auto ecu same year
hek1620
Car: '89 240sx
what autos don't have s. limiter?
SOHCSE
Car: 1990 240sx SE
hek1620 wrote:what autos don't have s. limiter?
I have a 1990 SE Auto, no speed limiter here. (hate the auto tho)
-Matt
TheOne
Car: 93 240sx FB
auto's don't have a limiter....also if you search you could probably get a better answer.
naed240sx
Car: .....
the fact that autos dont have a limiter is very strange. What are they expecting chicks and non-serious sports car people to drive them and be to scared to push it?
SOHCSE
Car: 1990 240sx SE
naed240sx wrote:the fact that autos dont have a limiter is very strange. What are they expecting chicks and non-serious sports car people to drive them and be to scared to push it?
Naah, I just think that they were just looking for a way to reward people for ripping the auto out and doing a 5speed swap.
JimmyMethod
Car: 97' 240SX SE
Do the Auto ECUs still have a rev limiter?
kamikazestorm420
how hard is it to put in an auto ecu?
coupebuddy
Car: 89 coupe 96 motor 93 harness 91 auto ecu cai,msd,plug wires,12v charged ignition,hyper grounded,stru
JUST PLUG IT IN,DUH
ca18det_boy
The auto ECU's do have a speed limiter to a certain extent. With the auto transmission the ECU says to cut out at a certain speed because it controls the shift points.. On the other hand putting an auto ecu in a man trans you control the shift points not the ecu so that eliminates the speed limiter.
RipShift
Car: S13 240sx fastback
so is the AT ecu really plug and play? It doesnt change any of the engine parameters or anything?
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
plug and play, and from what devious said to me once, there should be a slight power gain around 2500-3000 when only at partial load, so its better for all around driving
SilviaS14KA24DE
Car: Doriftu
So can the manual ECU to auto ECU swap be done in a 95 240?
SilviaS14KA24DE
Car: Doriftu
anyone?
SilviaS14KA24DE
Car: Doriftu
someone MUST know TTT
ca18det_boy
yes it can
