display temp radio 08 sentra
sanpague
Car: nissan sentra 08
Does anyone know the location of this sensor? I think it is located in front of the radiator, but can someone with a 2.0s check? I have a 2.0 and just swapped out my radio for the 2.0s information center--everything works except for the temperature reading. I think I'm missing the sensor and would like to install it...the problem that the display shows -22 F and does not change....
Faja
Car: 2009 Nissan Sentra
There are 2 sensors on the front radiator support right behind the grill. I believe one is the crash sensor and other is your temperature sensor - I'm not 100% certain, maybe one of the techs can shed some light.
sanpague
Faja wrote:There are 2 sensors on the front radiator support right behind the grill. I believe one is the crash sensor and other is your temperature sensor - I'm not 100% certain, maybe one of the techs can shed some light.
look behind the grill and found a yellow plug sensor.
I think is that crash sensor airbag light lit on the board, but can not find another cable to connect any sensor
Faja
Yeah, you probably don't have it because your car didn't come initially with that option. You will have to buy one and wire it up.
