So far we love this think! Bought the truck from a local dealer. Started digging around the truck when I got it home. Found a mess of wires under the dash. Started poking around and noticed an after market Nav system installed. Not only did the system not work but it was interfering with some of the stock electronics. The auto dim on the display screen was not working with the headlights and the display screen was fuzzy when the key was turned to acc. Frustrated, I contacted the dealer and got everything removed. At first the factory security system was malfunctioning after removing the after market system, I knew it would screw something up! Went right back in to the service department and the tech took the car back into the garage. Finally, all the electronics are back to normal but now there is a gap between the factory display screen and the trim, I'm not sure why. There was a touch screen on the after market system that filled in this gap, but was removed with that system. It looks as though there was a protective screen removed to accommodate for the new touch screen. I hope I haven't confused anyone, I guess that is what pictures are for. I'm still fighting with the dealer to get this issue straightened out, although I don't hold much hope that it will be fixed. Just trying to see if anyone has knowledge about these units. Although the display screen works fine, the space is going to bug me. I may just need to buy a new screen and install it, this should fill in the gap. Thanks for listening to my sob story...lol.
[/img]
