TurboMax67 »
https://forums.nicoclub.com/turbomax67-u32502.html
Wed Sep 28, 2005 8:29 am
Go to Radioshack and buy a 5pack of 470k resistors (1/2 ohm incase they ask, .99c) and unplug the subharness and pop a resistor in there with some electrical tape covering it. You will automatically be able to tell a difference in power and there should be no code appearing. Make sure you reset the ECU before you go for a drive.
Maxhopper, if you disconnect it from the subharness the ECU will automatically switch to the 'Safe' timing path and you will trouble pulling away from Accords.
