RedDario »
https://forums.nicoclub.com/reddario-u4159.html
Fri Jan 10, 2003 7:49 am
I understood most of it, and thanks for all of your responses, but there's another thing I don't get: If the dropping resistor should not be disconnected, then why was it placed in an easily reachable spot, and why would it be so easy to disconnect? Shouldn't it just be part of the A/T computer's circuits?
A better solution that I found, so I don't blow up the transmission, would be to put in a switch on the dash so that I can turn this on and off while driving. I'll tell you how it turns out.
