disconnected wiring engine bay S13 KA24DE
JayS13Project
Car: 1991 240sx Fastback Base model with issues.
This.wire is.disconnected it runs from the group of wires that comes from the fuel rail Passenger side of motor to the drivers side near the end of intake Any idea of what it could be?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Looks like the power steering pressure switch. It idles the motor up when the steering is at full lock. Should be a Brown wire and black wire.
JayS13Project
Hijacker wrote:Looks like the power steering pressure switch. It idles the motor up when the steering is at full lock. Should be a Brown wire and black wire.
Thanks for your response. Where would.I find the other end? Near the steering rack?
Hijacker
'94 F-150
The high pressure hose. If you follow it from the pump to where it meets the 90 degree steel fitting, the switch is located there. It's unnecessary for the car to run as all it does is tell the IACV to bump the idle a few RPM to compensate for the pump strain having the rack at full lock. I haven't had mine hooked up in over 8 years since the car was swapped with an SR. I deleted the switch last year when I replaced my high pressure line.
