C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Mar 23, 2004 3:34 pm
The Disco Potato is very responsive because of it's size. Both the turbine and the compressor fit within a housing whose outer dimensions are similar to a stock T25 on the SR. This combiones with such a high efficiency for such a small turbo makes it a great turbo for moderate boost. But it's peak flow is a lot lower than a T04E, but if you are working within a limited boost range, it works fine. Chances are you are not going to get the same response with a T3/T4. The T3/T4 has a larger compressor and turbine wheel, which means it requires more air to drive the turbine, and it has more mass to move around. The T3/T4 is still quite responsive. You can try using one of the smaller turbine wheels coupled with a lower A/R, but if you have a goal of 350 HP+, a small turbine will be like "chasing one's own tail". You can't have your cake and eat it too. Some compromises will need to be made.
As far as cost, a ball bearing T3/T4 will usually be higher than $6-700. It might even be nearly as much as a DP.
Also, keep in mind the Miata is a smaller motor and puts out less exhaust energy for a given RPM. The DP would spool up very quickly on a KA.
My opinion is that you won't be dissatisfied with the response of a T3/T4. Especially with a BB center section. I've driven one before and while it wasn't instant on/off boost, it certainly was spooling quickly. And this considering I run a straight T04B and I'm happy with the response of it.
