Postby
redamnavit »
https://forums.nicoclub.com/redamnavit-u13408.htmlFri May 28, 2004 5:40 pm
I picked up an old set of 3-piece Volk meshies that need some serious cleaning, and I'm considering painting the mesh section as well. Is it safe for me to dissasemble/reassemble the sections myself? Any suggestions on how (and how much) I should retorque the bolts down when I reassemble them? Thanks.
Postby
Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.htmlFri May 28, 2004 5:40 pm
On an older 3 piece wheel I would replace the studs if you remove them. In either case I would replace the studs on ANY 3 piece wheel if I removed them for safety reasons. Just the same as I would never re-use head studs.
Postby
daniel »
https://forums.nicoclub.com/daniel-u16619.htmlFri May 28, 2004 5:40 pm
you could disassemble them
we do it to flip the wheelsjust go in a star type pattern so relieve tension evenly and to not distort any one part of the wheel
the nice thing would be to go ahead and do it just when you're putting it back put the actual wheel part (not the center) into the oven at about 175*F for ohhhh like 30 minutse to get it to expand a little and put the center portion into the freezer to get it to contract
