benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Tue Apr 26, 2005 8:39 pm
89 240?
There are two. The one in the grip, and one toward the front of the door close to the top. It looks like a recessed button. You can't miss it. Flip open the "button" and the screw is beneath. After that the door panel pulls off and up. It uses fasteners that just pop out of place. After you remove the screw in the grip, you'll need to pop out that plastic grip piece and disconnect the window switch harness from it. Also remove the plastic piece surrounding the door handle and lock. It's hard to explain, but it pulls off. You'll need to use force, but don't pry it with any tools.
