If it doesn't work, wouldn't you like it to? It might be as easy as replacing 2 relays.Kiven422 wrote:I'm trying to disable the TCS system.
Why don't you use the console switch, then?Kiven422 wrote:I'm trying to disable the TCS system.
Maybe you need to read more and destroy less?Kiven422 wrote:Look, I just don't like TCS, in any car. On top of that replacing the relays may fix it but TCS has been nothin but a pain.
Simple. Yet quite to the point.ILuvNkdChx wrote:Just remove the bulb.
Pull the dash light from behind itKiven422 wrote:... Just would like to get rid of the SLIP light... anything else I can do other than replacing the relays?
