tom240 »
https://forums.nicoclub.com/tom240-u4479.html
Sat Jan 25, 2003 3:36 am
this is from the FAQs....
Quote »"After reading the first solution I looked into finding a simpler solution. Best of all, everything can be done at the computer. My car is a 89 with a 96 ka24de, but all the wiring and computer is 92. On my computer, there is a yellow wire with green stripe, 8th one over from right on harness. This is the vehicle speed sensor signal. Cut that wire. That is it. If you have a California car I think it will trigger a code, but for the rest of us, it is an easy trick. Your speedometer will still work because the signal comes from the transmission, goes to the gauges, THEN feeds the computer. I had to find a solution because my car comes very close to the speed limiter at the end of the 1/4. If anyone can beat the revlimiter let me know. I'm working on it."[/quote]seems too good to be true. has anyone tried it, and does it really work? also, my car is a 90 so will this work on my car? thanks.
