Disabling ABS (pulling the fuse)
raceman229
Car: 1990 300zx
Hi this may be a dumb question, if I disable the abs will I still be able to stop the car? I ask this question because the abs in my 1990 z n/a always seem to engage when I hit the brake and the ABS light comes on. Its not bad but it shakes the car a little bit when I stop. I dant care to much about abs I know how to not lock the brakes in a panic stop. all feedback appreciated.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
That means one of your ABS wheel sensors is bad. It's providing a false indication that you are skidding when you aren't.
Yes, you will still be able to brake.
raceman229
Car: 1990 300zx
Ace2cool wrote:That means one of your ABS wheel sensors is bad. It's providing a false indication that you are skidding when you aren't.
thanks!!!!
