Disable VVCS on a 2019 Rogue (variable voltage cobmntrol system)
Your stop for everything on Nissan's performance brand. Whether you're looking for info on the new Sentra NISMO concept, the GT-R NISMO, 370Z NISMO, or just some of the many NISMO branded parts - You're in the right place.
hotrodjohn71
Car: 2010 Nissan Rogue
Can anyone share some insight on how to disconnect the variable voltage control system on our 2019 Rogue so that the alternator charges without any input from the ecm? I have seen tutorials on how to disconnect the single wire Style on the older versions but this has the multi-wire style. Thank you
hotrodjohn71
I now have a vety specific question.
If you have access to the electrical manual for the 2019 Nissan Rogue, can you tell me which wire (color) and which pin # in the IPDM sends the charge signal to the alternator?
This will be the single wire that the IPDM uses to send signals from the VVCS (variable voltage control system) to the alternator to control charge voltage.
Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The gen2 Rogues from '17 up have a LAN alternator and not PWM. Because it's a bidirectional bit-bang and not unidirectional like PWM, you can't disconnect anything on the alternator without lighting the MIL and the generator lamp. The only thing you can do is disconnect the battery current sensor, that will cause codes but won't light the MIL on most models.
hotrodjohn71
Thank you for your help. I appreciate it.
If you look at my photo above of the wires attached to the ground cable, do you know if that whole plug constitutes the current sensor, or is it one of those individual wires?
Thank you
VStar650CL
Technical Expert
Those pics are the battery current sensor, none of those wires go to the alternator. You can just take the whole connector loose to disable sensing. Those particular connectors can be very stubborn, so to avoid breaking anything, I strongly suggest dousing the whole shell with WD40 or PB Blaster before trying to release the latch.
hotrodjohn71
Thank you!
Return to “NISMO”
