Disable tire light?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
vicmat
Car: 2010 Infiniti EX35
2004 Corvette
2010 Santa Fe
2012 Santa Fe
I have a 2010 Ex35 and put winter tires on. They dont have TPMS sensors so they activate my low tire pressure light. Is there a way to temporarily disable the light by pulling a fuse or bulb, and then changing it back when the summer tires come back on?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
I believe the short answer is no. There's no fuse just for that little light. Others have simply put a piece of black tape over the light.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Definitely nope. The TPMS functions are all integral to the BCM and you can't disable that. Nor is there any BCM configuration option to disable it.
vicmat
2004 Corvette
2010 Santa Fe
2012 Santa Fe
So then black tape it is. When I get new snow tires I'll probably spring for the sensors. Thanks all, for your inputs.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
