Fairly easy to do. If you go to the the FSM (factory service manuals) here you will get all the information you need.smithm7 wrote:I'm new to the forum, so I hope I am posting this in the right location. I am interested in trying to disable the safety feature on the Infiniti G35 navigation, which prevents programming while the car is in motion. I have a 2007 G35 Sport 4DR. In addition, if I could enable the screen to play video while the car is in motion that would be a plus.
It looks to me like if you wanted to you could remove the multifunction switch and install a relay that would disable the speed sensor and brake when the aux was pushed (or any non-nav related switch for that matter). Reenabe it when any nav related button was pushed. Some consideration would have to be taken for something like Info, status, etc.smithm7 wrote:I'm new to the forum, so I hope I am posting this in the right location. I am interested in trying to disable the safety feature on the Infiniti G35 navigation, which prevents programming while the car is in motion. I have a 2007 G35 Sport 4DR. In addition, if I could enable the screen to play video while the car is in motion that would be a plus.
smithm7 wrote:Thanks for the info. Btw where did you get your body kit?
terrycs wrote:I recently installed the HKS CAMP2 in my car.
For those that do not know, the HKS CAMP2 is a digital gage display that is capable of monitoring various engine parameters using either the factory sensors, additional sensors or a combination of both. This is a screenshot showing 6 gages on the factory LCD:
In order for the gages to be displayed while the vehicle is in motion, you have to:
1) cut the parking brake signal to the head unit and ground the side coming from the head unit. No, you will not get a parking brake warning light in your dash because this is just a signal to the head unit.
2) put a 2 position switch in line with the vehicle speed signal. When the switch is closed, you will have normal navigation (if so equiped) function. When the switch is open, you will be able to view your CAMP2 display BUT your navigation will not refresh fast enough. You can locate the switch anywhere convenient.
To determine which wires to cut and splice, here are the pin connections for the back of the three head unit configurations available:
Thanks for the link. Looks like they have a lot of great things. I am curious if anyone is familiar with them reagarding quality and ease of installation?bschurr wrote:The easy answer is here --> http://www.kptechnologies.com/products.php#/6
I have not used thier products (yet) but after doing a BUNCH of research they seem quite reputable...Good luck
A relay could certainly work, but in this case, the ebrake signal serves absolutely no purpose except as one of the lock outs to the nav functions in the HU. There will never be a reason to reconnect it.pfarmer wrote:
I would like to see using another connector so you would not have to cut the original.
Perry
I don't have a body kit. That's the factory body work.smithm7 wrote:Thanks for the info. Btw where did you get your body kit?
I also have the KP Tech module in my car. Very straight forward installation if you are comfortable with automotive wiring. You'll still need to cut the VSS wire though. With the KP Tech module, you operate the relay from the OK button. Another bonus with the module is that it also auomatically presses the OK screen on initial start up.smithm7 wrote:Thanks for the link. Looks like they have a lot of great things. I am curious if anyone is familiar with them reagarding quality and ease of installation?
Can the pins be released from the end? While the connector is proprietary the pins may not be. I have done this on many other connectors which allow not doing any cuts so you can restore to original if desired.terrycs wrote:A relay could certainly work, but in this case, the ebrake signal serves absolutely no purpose except as one of the lock outs to the nav functions in the HU. There will never be a reason to reconnect it.
So that leaves only one wire (VSS) that really NEEDS a switch for proper nav function. And this wire may not even be needed if you do not have nav. A relay would be extra work in this case.
I thought about making a pigtail as well, but that would require a damaged HU and a harness for donor connectors. The HU has proprietary connectors.
The OK button as used in the KP Tech module essentially triggers a relay. The module can be programmed for timed operation after the OK button is depressed, or latched so the OK button has to be pushed each time you want to switch between nav operation and AUX operation.pfarmer wrote:However in the case of the Nav I am not so sure there isn't another solution. I have noticed that without the car running, such as if I am simply programming it I don't have to push the 'Ok'. Is there something we are ignoring?
Perry
What I am referring to is that if the car is not running and I want to program the nav I do not have to press the OK button to clear the warning screen first. As soon as I start the car I do. This indicates to me that just maybe there is another way around the OK button than simply simulating pushing it.terrycs wrote:
The ideal solution is to go directly to the nav screen. I haven't had time to mess with it, but it essentially takes an RGB input. If there is a backup cam on the car, I believe the LCD actually has multiple inputs.
