Disable Keyless
Home of the Nissan Cube forum and CubeDriver.com
Wjmartin
Car: 2007 Nissan Cube
Cube 2007.
I would like to disable all of the keyless access on my Cube. I have already established that if the Fob is not present I can unlock all the doors using the key. Once inside I can start the car with the key. And after, I can lock the car up and repeat.
Is there a way to disable keyless so that only an actual key holder can use the car? And so that somebody with a copy of the Fob cannot get in.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
We only have the gen3 Cubes here in the 'States, but if the remote entry is similar, there will be an RKE antenna/receiver behind the glove box. Should be a small, rectangular module with a 4-pin connector. Unplugging it will prevent the BCM (or SEC, as your case may be) from receiving fob signals.
Wjmartin
Excellent, thank you. I will take a look for something similar on my Cube.
VStar650CL
Technical Expert
You're most welcome, let us know what you find.
Return to “Cube Forum”
