I've got a 1993 J30T. The lines feeding the HICAS system are leaking. Replacement is rather expensive. I read on a 240zx forum that you can just pull the fuse on the HICAS and bypass the lines from the power steering pump to disable HICAS. They indicated that there is no need for the HICAS elimination kit unless you want to save on weight. My mechanic is looking at how he might install a bypass for the fluid, but I cannot identify the correct fuse to disable the HICAS. Does anyone know which fuse to pull? Does anyone have any other thoughts on how to deal with this?
FYI - there is some pretty bad rust and I only want to get thorugh the winter before selling the car to a scrap parts yard.
