Disable Brake Pad Sensor... ???
Meaux
Car: 94Q45, 92Porsche 968, 72Porsche 911, 89Maxima SE, 98Honda Civic, 85F150 w/95 5.0
94 Q45 87K
Did a search, disable brake pad sensor, brake pad sensor, pad sensor, worn brake pad...
Nothin...
How is this done... Just unplug??? Cut and tie wires together??? Cut and separate wires???
Thanks....
Q451990
Cut the wires off of the sensor side so that you have the plug and two bare wires. Don't cut the wires on the harness side in case you want to go back to the OEM pads.
Twist your bare wires together (or better yet solder them) and plug in the cheater plug you just made. All you're doing is completing a circuit - the sensor used to complete it, but when it rubbed against the rotor it wore the "wire" through.
Remember that there's a sensor on both the RF and RR wheels.
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Q451990 wrote:Remember that there's a sensor on both the RF and RR wheels.
Heath
I think on some of the later models it is one or the other, or in the case of both my 1995, none at all.
Meaux
So, I assume the OEM Pads come with a new Sensor ?
OK thanks...
Q451990
Meaux wrote:So, I assume the OEM Pads come with a new Sensor ?
Yes. I usually have to do this cut-n-twist method while I'm ordering new pads from Joe.
Heath
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
OK thanks...
Yes and no. Depends. Why it's always a good idea to order with your VIN, them IoS will know if your car has sensors, and at which ends.
Jow knows my two 1995 don't have sensors so sends me OEM pads without them. The first time he didn't though.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I order OEM pads from Joe and they always include the sensor. All I do is replace and everything is as it was designed. If you switch to different rotors and stuff you'll have to override it or if you use aftermarket pads.
AlabamaDan
1998 Infiniti QX4
Sometimes it's how you do the search. Try this:
Searh for BRAKE PAD WARNING
Choose archived content
Choose to search post bodies
this should give you plenty.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
AlabamaDan wrote:I order OEM pads from Joe and they always include the sensor.
Then you are paying too much as the sensorless OEM pads are less.
AlabamaDan
1998 Infiniti QX4
Let's not go down that road again.... :
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
AlabamaDan wrote:Let's not go down that road again.... :
Been there, done that. Won't do it again, thanks to Joe and VIN.
Meaux
Update:
Finished the front brakes yesterday and all is well...
Pulled the rear wheels this AM and removed the Left Side pads... Almost metal to metal...
On to the Right Side... I notice the pads are almost as thick as New pads... Humm... Went to loosen the top Pin and the Head broke off... OH NO!!!Seems the Pin has been frozen, and the caliper hasn't moved in a Coon's age... Soaked whats left of the Pin with PB Blaster... I'll try and get it out tomorrow... What a PITA.
Caliper seems OK, but I'm afraid the "Torque Member" is gonna be trashed... Jeeze...
Sorry, had to vent...
AlabamaDan
1998 Infiniti QX4
Got nearly the same problem. I think it's common if we don't clean and lube that caliper pin regularly.
