dirty headlights
TurboKA37
The headlights on my 240 look a bit foggy and have a yellowish tint to them. any ideas on how to get rid of this? ive heard of wet sanding the headlight covers, but wasnt sure if this worked. I want the headlights to look clean and rid of the yellow tint.
lDeeZ lNuTz
get some plastic compound (any sort of plastic cleaner) and start rubbin on the headlights, it takes a LOT of rubbing btw. mkiv supra owners have the same problem, but their's seems to be on the inside of the headlight, try cleaning both inside and out.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
GirlRacerS14
Car: Cars and motorcycles and racing both of them hard and fast
Here is a really good post about cleaning headlights. Third post down by Touchdown038 has a link on how to thoroughly clean your headlight lenses. (originally posted by stickgoat i believe, thank you by the way)
GR
240SXedUp
You should really really really really really try the SEARCH button before you ask questions. You would find this thread:http://www.nissaninfiniticlub....ights
stickgoat
240SXedUp wrote:You should really really really really really try the SEARCH button before you ask questions. You would find this thread:http://www.nissaninfiniticlub....ights
Yes, that is my thread....go read my how-to. It really works. Someday I'll do it again with pics. :)
TurboKA37
thnx for the help
TurboKA37
im gonna do the proccess tonight, do u want me to take pics of the proccess and post them?
TurboKA37
ok i did ur proccess tonight and it didnt go as planned. the residue from the nail polish was impossible to get off and the metal polish i was using was non-abrassive so that could have been the reason it wouldnt come off. after continuing with the steps the head lights looked pretty bad so i went in search of some very fine sand paper in my basement to try the wet sanding tecnique. I found some 600 grit paper and sanded the headlights down which got rid of the residue left from the nail polish remover but made the lense look really foggy when dried. I figured it was cause from very small scratches from the sand paper and i used McGuire's 3 step wax proccess which really restored the lenses and got rid of the foggyness. I noticed that the nail polish remover did take the yellow tint out of the lights but the stuff left behind was very hard to get off. overall i am pleased with the outcome and the headlights match the color of running light lenses beside the headlights a lot better, which is what i wanted. sources of error may have been that i didnt use the same brand metal polish u suggested and the metal polish i did use is about 20 yrs old and didnt look like polish when i first opened it. I did take pictures of the before and after if anyone wants to see them but it was dark out and the flash on the camera makes it hard to see the difference but they are clearer. thnx for the help again.
prigo
I just use a wet towel, and a lot of elbow grease, works well for me :|
