Our cars dont have WOT switches AFAIK. The TPS is our only means of throttle measurement stock.DAEDALUS wrote:It's called a TPS switch, but it looks like it's just an on/off switch that you can set the "on" point to depending on throttle angle. Not variable like the TPS itself. If this is the case, why not save yourself $80 and tap into the WOT switch built into the car? I assume all 240s have a WOT switch.
