direct bolt on electric cooling fan kit
ZackRidesRed
Car: 93 240sx coupe, auto,
I am new and have searched the forms and the internet, and haven't been able to find a performance electric fan that is a direct bolt on replacement for the mechanical cooling fan for my stock 93 coupe that covers all of the radiator core. I am planning on making making a kit myself and wold like it to fit the 89-90 s13 and the s14 as well, I was wondering if i could get any pictures and/or specs of any differences in radiator mounting and core size.
ZackRidesRed
this kit wold not mount through the core
e_c
Car: 1990 240sx
look at 97 altima electric fans
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
^^^ Yep...Altima fans.
Junk yard, $50-75 depending on condition.
The shroud is almost a direct fit, but you have to trim an inch off of bottom corners.
It house 2 fans...you can use your stock wiring for the smaller one, and wire the bigger one to a switch.
Works great on my ~300rwhp KA-T, on and off the road course.
- Brian
ZackRidesRed
I am talking about something new with a guaranty/warranty and pulling 3000 cfm+ (zero static pressure numbers) for $350 or lesswith a Variable Speed Control 60% to 100% and a 160° to 220°F thermostat, the fan could be set to run up to 30 seconds after the ignition is off.
Infidel
Car: 1995 240sx
i know flex-a-lite sells electric fans, but they are universal. I bought a 10'' puller fan for $220 with a thermostat control, i havent installed it yet. You could buy these at any auto parts store, i bought mine at Pep Boys, dont know if this info helps.
moyea
Car: Paddle Shifted 92 240SX SR20DET, 02 Frontier S/C, 90 240sx ITA
Some guys did a test on several electric fans and the Altima fans actually outperform the Flex.
Think about it......$75 or $200+
Do yourself a favor, you would be glad you saved the money for that turbo I know you want.
