Dipstick blown out
TurboTuli
Car: s13
Hey all,This weekend at a drift event my dipstick blew out about an inch and oil sprayed everywhere. Obviously high oil pressure caused this, but what would cause my pressure to go that high? It happened to me twice in a row and then I quit driving and coincidentally it happened to the only other guy there running a CA...Crazy! I was able to drive it 100 miles back home with no problems whatsoever...Let me know.
boost_boy
TurboTuli wrote:Hey all,This weekend at a drift event my dipstick blew out about an inch and oil sprayed everywhere. Obviously high oil pressure caused this, but what would cause my pressure to go that high? It happened to me twice in a row and then I quit driving and coincidentally it happened to the only other guy there running a CA...Crazy! I was able to drive it 100 miles back home with no problems whatsoever...Let me know.
It's not high oil pressure, but a process called "blow-by" which is a process whereas your pistons and/or rings are worn to the point where they allow pressure from the combustion chamber to get past them and into your sump area creating pressure in your oil pan at which time that pressure will find the weakest point and find it's way out. You will usually find oil spraying out of your exhaust cam cover's breather hole, but if you blew out your dipstick a bit, rest assure you got it bad!
Dee
TurboTuli
Car: s13
hm, terrific...the guy I bought the car from had the exhaust side breather hole cut and welded shut cuz he thought it was just for emissions crap...you think that alone would cause this, or are my rings probably bad either way?
p.s. anyone have an exhaust side valve cover for sale?
Modified by TurboTuli at 9:16 PM 11/14/2005
themadscientist
I thought blowby was when you beat someone in a race So your exhuast side valve cover breather is plugged up? That is not necessary, uncork it if you can. If you are spitting out dipsticks though I would suggest taking your drift event entry money and saving up for some rings and machine shop fees, you will be needing it soon.
boost_boy
TurboTuli wrote:hm, terrific...the guy I bought the car from had the exhaust side breather hole cut and welded shut cuz he thought it was just for emissions crap...you think that alone would cause this, or are my rings probably bad either way?
I got one for sale! Give a zip and I'll give you a shipped price. Looks like you'll be needing an engine refreshening very soon. Hey "mad" blowing by someone is not called "blow-by"; it's called smokage
Dee
TurboTuli
Car: s13
zip is 97403.
Any estimate to what I'm lookin at for having my rings replaced? anything else I should have done while they're at it...? god, I love cars. just got this ***** running like 2 weeks ago...
pulsar gtr
Car: NISSAN VEHICLES
lol, he had the breather welded, your buddy didn't get a hint on why this happens.
As the above members mentioned, your rings are finished. It will be cheaper to go with Dees ways and buy another engine.
PULSAR GTRRafi
boost_boy
TurboTuli wrote:zip is 97403.
As for the cover $20 shipped. Rebuild::::::
oil pump= $200
water pump= $55
Rings= $100
Rod and main bearings= $100
Stock headgasket= $60
Replace head bolts= $50
Cleaning and light honing of block (optional)= $150
Clean-up and resurface head, replace valve seals, and re-cut valves= $150
Hope this helps..........
Dee
biosehnsucht
could also be the PCV system failing while on boost.. i.e. if the breather from the valvecover to the air intake is not hooked up, and you have some not fatal blowby, could still cause that to happen..
you'll always have SOME blowby, normally it should be consumed via the PCV system.
a VERY good explanation of how PCV systems work (from a friend's thread on upgraded PCV's on another car forum, forum registration required unfortunately): here
float_6969
It's important to have the PCV system hooked up properly, ESPECIALLY on a boosted car. A N/A car will hardly ever create enough crankcase pressure to blow the dipstick out. But my freshly rebuilt CA w/an improperly hooked up PCV system will still kick my dipstick out occasionally. Just to double check that I hadn't botched my rebuild, I jury rigged up a small vac pump to maintain a negative pressure in the crankcase and then went out for some full boost runs on the highway. It instantly alleviated my dipstick problem. If I ever get an intake on my turbo so that the system is hooked up properly, I'm sure it will stay in.
biosehnsucht
my stock KA blew out the dipstick once.
I'm pretty sure the CA never has.
TurboTuli
Car: s13
yeah, I talked to the other guy that this happened to and he said his shop said it is most likely the pcv valve. Both of our motors have been compression tested and were good across the board and I've only had mine running for 2 weeks...I'll look into it and let you all know
sideways danny
Car: s13, CA18DET
blocked breathers (the one from the block undcer the plenum especially) would do this
TurboTuli
Car: s13
Hey Dee,Can I still get that valve cover from you? I can paypal today. e-mail me at turbotuli(at)yahoo.com
boost_boy
Yea
TurboTuli wrote:Hey Dee,Can I still get that valve cover from you? I can paypal today. e-mail me at turbotuli(at)yahoo.com
Yeah, I have many of them.
Dee
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
150 for light honing of the block?! man, go borrow the tool from auto zone and do it yourself for free. if i can do it without screwing something up, anyone can.
sorry, i just saw those estimated prices and was a little shocked. i replaced every gasket on the engine and it didnt cost that much! (and the bearings are only a few bucks each at advance by the way, for clevite 77s) just for future reference! please dont kill me!
- tim
float_6969
We won't kill you Tim. We might beat you with a lama though...
