gavnator wrote: ↑Fri Feb 02, 2018 11:05 am
I'll probably will stay with conventional oil. I don't put a lot of miles on the M and in most cases take the car in for oil changes much before the 3250 mile marker based on a timeline. The car runs great so I guess I won't mess with success. Thanks for comments.
If you change often (like you do), then almost any decent dino oil will be perfectly fine!
Consider using a good dino 5W30 (depending on the area you are in) with some additives, if cost is an issue. Examples: Castrol GTX, Quaker State, Pennzoil, etc.
FWIW, I started using Mobil 1 Synthetic 0W-40 from about 10k miles on in my 2003 M45 with an interval of 3750 miles for changes.
Now that I am over 204k miles, I tend to let it go a little longer (like 5k miles or so).
Z
