szh »
https://forums.nicoclub.com/szh-u149.html
Mon Apr 09, 2007 7:18 am
Hi, Mark.
I would recommend switching to a synthetic, certainly after a reasonable break-in period (if you believe in this) with dino oil - say around 10k miles or so. Since you have used Mobil 1 before, you should stick with it, I would think, but any of the good synthetics will do well!
For example, I use Mobil 1 0W-40 in my car and am perfectly happy with that. I add 1/4 to 1/3 qt (sometimes 1/2 qt) every 1750 miles (halfway between my oil change period) and the expense is minor, relatively speaking, to every other expense of operating the car.
Again, as our resident experts also say, it is far more important to do regular oil changes - no more than 3750 miles apart - rather than worry about which oil per se. If you use a good dino oil (like Castrol GTX 5W-30 for example) and change every 3k miles, that would be just fine too!
Z
