Hey guys,
I've been reading everything I can find online about dingy towing my 1999 Infiniti QX4. I just can't find an acceptable answer. I have read people say that it should be fine if you remove the rear drive shaft. Lets assume that I will do that no matter what. How about the front transfer case? Will that be fine towed? I'm wondering if I need to pull the front drive shaft also. If I then pull both drive shafts is there anything else that could cause me problems?
Obviously the manual says no to Automatics, but yes to manuals. I have an automatic. I've looked at my manual and it says something like the link below, also, I've looked at the 1999 dingy towing guide, which says this (second link)This leads me to believe that if I disconnect only the rear drive shaft I would be fine, but I want to know for sure. I do eventually plan to get a trailer, but that's just not happening this season so I need to know. Thanks for chiming in.
Manual Instructions:
https://www.justanswer.com/nissan/2lwz0 ... nd-rv.html
Dinghy Towing Guide:
http://images.goodsam.com/newmotorhome/ ... yGuide.pdf
Found some good info here, but still incomplete:
http://www.nissanpathfinders.net/forum/ ... -a-towbar/
Even remco says that this vehicle must be towed with a trailer:
1999 Infiniti QX4 ALL 4WD V6 3.3L cyl 4-Speed Automatic JR402E
Notes
Must be towed using a trailer
