Veriest1 »
https://forums.nicoclub.com/veriest1-u15441.html
Thu Sep 28, 2006 7:46 am
Here's what I'm thinking...
If I buy a typical BOV w/ a steel mounting flange I can weld a short section of pipe to it that I can put a hose on like in the picture above. This shouldn't hurt anything and will be cheaper than AA's stuff.
Is this, in referance to the HKS SSQV all hype, "dual stage pull type relief valves that by design do not leak under high boost conditions or under idle vacuum and is actuated by pressure alterations to ensure a quick primary and secondary valve response. For maximum performance, the HKS SSQV incorporates both a small primary valve for ultra quick activation, along with a larger secondary valve for additional discharge capacity. The SSQV is engineered to initially open the small primary valve at light throttle and load conditions, then sequentially opens the secondary valve for additional relief capacity under high boost and load conditions." Or does it really work well because if it does it sounds like it would be perfect for a cenrtifugal supercharger that sees low boost and high boost throughout the RPM range. I need some feedback and would like to be better informed before I talk to tehe guys at Enjuku about this. I hate wasting peoples time if I can avoid it.
