WeldingHank wrote:I Have my boost,water temp, and oil pressure gauges down where the pocket used to be, i made my own pod. so yes, you can put them down there :-)
Is the pocket actually DIN sized? Just by eyeballing it, it seems smaller. Also, when the center console is removed, does the actual pocket part come out?
It just seems like 3 52mm gauges would be a really tight fit in that small space.
As much as I love the DEFI stuff (it looks awesome) I'll probably be going with more economical Autometer gauges. Looking at voltage, oil pressure and water temperature.
