Dimmer Switch Relay?
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
My dimmer switch went out finally and when I replaced it, it didn't work. I checked all the fusable links and everything's aok. I couldn't find a relay in the service manual. Anyone know if there is a relay for the illumination switch?
chuongcom
Car: car,computer
Please tell me how you replaced the dimmer switch. Thanks.
Q45tech
Are you referring to the 4 relay head lamp selection assembly [module] located in the rear corner of drivers side engine compartment? Each bulb has its own relay driven from stalk switch.
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
The switch I'm referring to is the dash dimmer switch on the console(dims the lights on the instrument panel). I replaced it and it still doesn't work. I know it was the problem from the beginning. Whenever it didn't work, I would just tap on it and the lights would come back on. I don't know what else would prevent the lights from coming on.
