daffyack »
https://forums.nicoclub.com/daffyack-u70433.html
Thu Feb 09, 2012 4:22 pm
I had LED lights under the foot for a while. and it was wired to dimmer switch so that it will turn on when the headlight is on. But now dimmer switch wont work, so all the LEDs are off. I checked the fuse but they look all fine.
so first I want to try to fix dimmer switch issue. does anyone know what's wrong with it? Do I simply replace it?
second, I hardly ever use dimmer switch if it werent for the LEDs.
So I'm considering wiring the LEDs to somewhere else. But I have no clue where I should wire them to so that LEDs turn on when I turn on the engines. Ideally, I want LEDs to turn on when the headlights are on, but if not possible, its ok to turn on when the engines is on. I was thinking about getting power from 12V cigar. But I don't know how to do that. Does anyone know how to do that?
or maybe getting power from fuse box But once again, I dont know how to do that.
so I would appreciate it if anyone can help me.
Thank you so much everyone
