Ok when I bought my Z32, it had a power problem over a year ago.
I got a new high output alternator put in, a new battery, Optima, made for long cycles, and the most life I can get out of the car is a week of battery power sitting by itself. This had problems since as long as I can remember.
I mounted the battery in the rear for weight distribution and it runs fine, but there is no change in the longetivity since I had it in the front.
I also had the battery wires redone and checked because of corrosion. Half the reason I moved the battery to the rear is to avoid atmospheric corrosion.
I do have an alarm system, and its very basic. I have a ton of add ons I need to put on for security, but the sensors I am adding will draw more power. I have barely enough as it is. I'm already going to do a battery back up for my alarm system because this is getting dangerous to leave the Z without security where I live. That at most will buy only a few days.
Ideas of mine-Install a backup system to switch over to upon a dead battery-Solar Trickle Charger
I don't know what to check on the car, what would be on? Is my alarm enough to drain the car battery with a blinking LED and 3 sensors over a 1 and 1/2 week period? Or are there common Z power drainage points to check?
I'm gonna pull out the ammeter soon and begin pulling fuses, tip me off if you know something tho
Sick of it...
Modified by gpelite at 8:05 PM 9/21/2006
