i will be doing a sr20 swap and probably a s13 rear end i am wondering if i will have problems with things like the drive shaft either not being compatible or long enough. will the factory drive shaft for the extended cab work with the trans and rear diff or will i have to use a single cab, not sure if this makes sense haha. i found the dimensions of length width and wheel base on wiki which make me think that the drive shaft and other parts would be longer or shorter. also wondering if the singles cab drive shaft is as long as stock 240s.
Wheelbase
104.3 in (2,649 mm)
116.1 in (2,949 mm)
Length
174.6 in (4,435 mm)
190 in (4,826.0 mm)
195.5 in (4,966 mm)
Width
65 in (1,651.0 mm)
1986–1992 & 1995–97: 66.5 in (1,689 mm)
1993–97: 66.7 in (1,694 mm)
1993–97: 67.1 in (1,704 mm)
Height
62.4 in (1,585 mm)
62 in (1,574.8 mm)
66.7 in (1,694 mm)
67.1 in (1,704 mm)
