ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Mon Oct 18, 2010 5:40 am
New battery---recharge externally. With a full charged battery installed:
Take battery reading all off---should be 12.5 at least
Take reading across battery at time of start---at least 10 V
Take reading at cold idle about 1200-1500 RPM---at least 13.xx v
Take reading at warm idle at 750 RPM---at least 13 V
Take reading at 2500-3000 RPM---maximum no more than 15 V
Get back with your readings.
The dim lights indicate a greater voltage difference between alternator and battery. Alternator may have worn brushes, bad battery will effect field with alternator.
The battery must be charged and verified good with a hydrometer not just voltage because you could have the voltage but no current.
