masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Tue Jan 25, 2005 12:30 am
As far as being able to use both the actual HUD display with the analog cluster, I can't be sure, but my best guess is that it probably isn't feasible.
The digital cluster uses an entirely different harness from the analog cluster. In the analog cluster, the signal from the speed sensor passes through a single plug with a few other signals, including those to the tachometer and temperature and fuel gauges. In the digital (HUD) harness, the speed signal is sent directly to the digital speedo, and does NOT pass through the cluster as in the analog device. Also, the HUD piggybacks entirely off of the speedometer unit, even for power. Therefore, without a digital speedo in the cluster, the HUD has no way of getting power, much less a signal.
Your best bet would be to find a SOHC analog cluster with a complete harness. The swap would be pretty easy because schematically speaking, the 240sx's "cluster" signals are identical behind the cluster subharness, with or without HUD.
Hope this helps!
