180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Apr 12, 2003 10:48 am
If you're gonna go to a junkyard to find an analog cluster, you'll need the instrument cluster harness for the analog. As stated, the analog and digital's use different instrument harnesses. Just a suggestion, if you are gonna go, just make sure you hold the cluster by the harness that you'll pull out along with the cluster. LOL. Some places won't notice it or if you're a bit more cautious, you can always hold the cluster by the clips on the cluster making it look like it's all part of the same wire. Just a few shady tips that might work. Or if you're going to be straight up about it, just tell the guy what's up and that you want that part of the harness.
