Geno11 »
https://forums.nicoclub.com/geno11-u9274.html
Wed Sep 24, 2003 11:47 am
Nate,I have the same problem and I read the posts on resoldering. I did finally show the unit to a friend who repairs all sorts of electronics on the side. He showed me all the fish eyes (bad /broken solder points, nearly all). His solution was to resolder all the connections but unfortunately one of my circuit boards was cracked (one with the large chip) from the previous owner. I installed an analog set till I get another set that works or one that can be reapired. There is a link to a company which repairs all sorts of digital units. They wanted $200 for a working unit with warrantee plus a repairable unit from you. They do have one in stock so check around the board for the link or go for re-soldering itGood luck.Gene..
