Digital speedometer problem...
dave8775
:help I have a 1993 Nissan 240SX SE with a digital speedometer that has recently gone blank on me. It started going off on occasions and now it is almost always off (though it sometimes still pops up again and goes out a few minutes later). When it is on it seems to report mileage accuratelly. Does that rule out a bad 'speedometer cable' or speed sensor? If that was out would the speedometer simply display '0' or would it go blank.
I have a feeling it is probably some contact, but since I do not know much about cars (though I am making an effort to learn) I thought I'd ask here if anyone has had a similar problem and knows how to diagnose/fix it. I have a friend who works on my car and he suggested that I perhaps need a new 'instrument cluster'... but I am hesitant cause it is expensive, and I feel it is not the problem. Could it be a bad contact as I suspect? Where would be the most likely location for such bad contact to occur?
Do you have any suggestions/comments?
Thank you for your help. I did try to search on the forum and did not find any solutions regarding this matter.
Cheers,David
NISTECH
http://www.nissaninfiniticlub....45498
turboex
I have perfect working hud unit. I used it one many 10 degree mornings and it always worked with out a problem. I swaped dashes and my new one does not have the hole for it, so its yours if you want to make me an offer.
rico05
Car: 1992 RMS13 w/ CA18DET
How much you want? Plus, any kind of warranty in case it dosne't work when I get it? I bought one "working" unit off eBay and sure as $hit, it was busted.
turboex
35bucks shipped. Trust me I just took mine out of my car, and it worked. Ill write a part number into it so if it does not "work" you can send it back and ill give you your money back. Ask for references on honda-tech.com user name turboex
