civiceater »
https://forums.nicoclub.com/civiceater-u8116.html
Tue Mar 09, 2004 12:42 pm
http://www.nissaninfiniticlub....45498
i know its been discussed ten million times...but at the end i still need help so from the thread above, i copied and pasted my last post:
bump!!! ok, NISTECH, i asked this question last year and it was cold so i wasnt able to get on it till today....now ive been reading up and down on all the threads about the "non-working speedos" now i came up with either its the radio that burned out the TCM? (is that right? its the small white box in the kick panel on the drivers side) well i took it out and pulled the circuit board, well it looks fine.... i might still go to the junkyard and get a new one, now next stop was the speedo input connector behind the speedo itself, i opened up the dash, pulled the cluster out, looked at the printed circuit board and it looks like new....no cracks or anything, however i did find one solder mound that has a hole in it but still have a good contact with the wire (should i resolder that?)...now i went ahead and pulled out the speedo itself and along came with the input connectors in the back, i looked at it and it seems fine, but one thing is bothering me, all the connections have brown stuff around the mound...is that the burn out? should i resolder that? (im not really sure what a burn out looks like so pardon me...) also you mentioned its either the control unit input connector or the cluster itself, now where is this control unit you're talking about? i got my whole car's driver side almost parted out....thanks for any input
al
btw, off topic, my hood hinge just snapped...well the driver's side, is it advisable to replace both? or should i just get one? thanks
