Digital HUD to Analog
boost infested
Car: cars, chicks, food, and .....
will the jdm sr20det gauge cluster plug into my 93 with HUD?
HUD just crapped out on me today. its annoying to drive my car with out a speedo. :mad:
quiksilvia
Car: 95 s14 se
the speed sensor will need to be swapped as the jdm cluster is setup for kmh, unless u have a sr motor
boost infested
quiksilvia wrote:the speed sensor will need to be swapped as the jdm cluster is setup for kmh, unless u have a sr motor
i am in canada, so it should be km/h.
yellow_jacket
Car: 95 240sx
You need the subharness from the donor car. The HUD harness and the analog harnesses are different. Plus you will want to remove the cat overheat light bulb and probably won't have the high beam light work.
