Digital gauges in Siliva?
ventrex
Car: 1993 Nissan 240SX Coupe
Im planning on buying a digital gauge cluster with harnesss and HUD. I have a SR20DET black top and was wondering what it takes to make it work? Also if its easy to get it to work. And ive seen people on ebay that made "templetes" for cutting the dash for the HUD module. Could anyone here do that for me??? and also where can i be the tint film for the HUD?
ventrex
can anyone help me out?
DDelambre
Car: '89 240sx, SR20DET, Silvia conversion
The wiring is the same for the digital cluster vs. the analog. It should just plug in if the new cluster has its harness. I have the digital cluster in my car and it worked with the SR20, just make sure the speed sensor is plugged into the transmission. Also, a cluster from an 89-90, the tach won't work with an SR, or dohc KA
ventrex
what do you mean by the speed sensor? shouldn't that already be plugged into the transmission?? i dont kno wut year the cluster is from, but i have a OEM sr20 analog cluster... could i swap the tach. from that?
ventrex
can anyone confirm all this?
ventrex
ventrex
anyone at all?
DDelambre
If you have an OEM Silvia custer, why not just use that, your speed will be in KPH, but that shouldn't be that big a deal. As far as swapping tachs, I think that the tach in the analog cluster is bigger than the digital, but don't quote me on that.
ventrex
i want digital with HUD because its so much cooler.
DDelambre
When I bought my car, the speedo/hud only worked about half the time, and therefore the odometer only worked half the time. They are pretty cool, especially since the car is 18 years old. The problem with them are the solder points in speedo itself crack, causing malfunction. I attempted to resolder all the cracked solder joints in mine, but to no avail. I just went ahead and ordered a new speedo unit through Nissan to the tune of around $350! Now the speedo works perfectly, but the odometer crapped out. Since the car isn't a daily driver, it doesn't really matter.
