Digital Dash (NEED HELP)
A home for 1983–1989 300ZX owners!
86300ZXVH45
Car: 86 NISSAN 300 ZX GL (non-turbo) 2 seater
I've got the 86 GL-L with digital, with a few problems.1a) left hand side has function which should read gallons left in tank from 5 down. Mine reads at full tank-5 (sometimes)1b) also reads 4 gallons towards 1/8 tankNever reads anything else! ?????????????
2a) Heat cannot be directed towards feet. With adjustment all the way towards floor, it seems to get really hot topside! Before I Know it, I have to shut off heat.Any help would be appreciated, any advise as to what other malfunctions might be on the horizon with digital will also work.Thanks, Bob
Pharaohabq
Car: 92' Nissan 300ZX NA
Well I don't remember too much abbout the digital dash, though I seem to remember the Dashes has issues with the dash computer. Best thing I can tell you is to try taking loose the connections and clean them out and put it back together. on a 20yr old car it's likely there's some cooroder connections..
Phar
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
could also be a bad sender, but I have no experience with them on the z31
as for heat, there are 2 vac lines that enter the cabin next to the battery ont he firewal, check them for cracks or breaks, they go to a cluster on the trans tunnel right next to the drivers feet, there si a series of dashpots that tend to stick or crack
86300ZXVH45
Thanks Gentlemen, I'll chase these down and advise outcome. Bob
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
The gas thing MIGHT be a sending unit at the gas tank. If that hasn't been replaced, it is bad.
If that does't work than you need to find someone that can troubleshoot.
the other issue is a vacuum problem. You might need to get someone to take apart a few parts of the dash to get to that, but with the automatic system they use vacuum to move the flaps.
Return to “300ZX (Z31) Forum”
